ronlaws
Sep 25, 2016Guide
Balance in progress (over 100%)
Is this normal? :smileysurprised: I'm starting to worry something may be up.
- Sep 29, 2016
Just an update on this:
Having now replaced all 4 drives in the array with new ones, the last re-balance i did only took a couple of hours, and did not go over 100%.
admittedly it only had to balance about 5 blocks, which took a while but at least it didn't drift off in to another dimension this time.
Currently doing a scrub which is also taking its time, but with any luck the issue seems to be resolved now.
Sep 25, 2016Guru - Experienced User
It's not something I've seen before. How long has the balance been running?
Also what firmware is running on the NAS?
- ronlawsSep 25, 2016Guide
It's been running overnight, it's running ReadyNAS OS 6.5.2. A sceduled Scrub also started at midnight, which i cancled this morning since this process was still ongoing..
Edit: Just checked to see if the process was still running, it appears to be?
root@ReadyNAS:~# ps aux | grep "btrfs" root 1158 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-worker] root 1182 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-worker-hi] root 1189 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-delalloc] root 1194 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-flush_del] root 1206 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-cache] root 1210 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-submit] root 1220 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-fixup] root 1225 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio] root 1236 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio-met] root 1244 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio-met] root 1249 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio-rai] root 1261 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio-rep] root 1274 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-rmw] root 1277 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio-wri] root 1286 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-freespace] root 1295 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-delayed-m] root 1302 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-readahead] root 1310 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-qgroup-re] root 1317 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-extent-re] root 1828 0.0 0.0 0 0 ? S Sep24 0:00 [btrfs-cleaner] root 1829 0.1 0.0 0 0 ? D Sep24 1:35 [btrfs-transacti] root 14276 1.8 0.0 3204 8 ? D< Sep24 20:12 btrfs balance start -dusage 64 -musage 64 /data root 32204 0.0 0.3 4216 1924 pts/0 S+ 12:23 0:00 grep btrfs
root@ReadyNAS:~# btrfs balance status -v /data Balance on '/data' is running 102 out of about 33 chunks balanced (159 considered), -209% left Dumping filters: flags 0x7, state 0x1, force is off DATA (flags 0x2): balancing, usage=64 METADATA (flags 0x2): balancing, usage=64 SYSTEM (flags 0x2): balancing, usage=64
