ronlaws
Sep 25, 2016Guide
Balance in progress (over 100%)
Is this normal? :smileysurprised: I'm starting to worry something may be up.
- Sep 29, 2016
Just an update on this:
Having now replaced all 4 drives in the array with new ones, the last re-balance i did only took a couple of hours, and did not go over 100%.
admittedly it only had to balance about 5 blocks, which took a while but at least it didn't drift off in to another dimension this time.
Currently doing a scrub which is also taking its time, but with any luck the issue seems to be resolved now.
Sep 25, 2016Guru - Experienced User
It's not something I've seen before. How long has the balance been running?
Also what firmware is running on the NAS?
ronlaws
Sep 25, 2016Guide
It's been running overnight, it's running ReadyNAS OS 6.5.2. A sceduled Scrub also started at midnight, which i cancled this morning since this process was still ongoing..
Edit: Just checked to see if the process was still running, it appears to be?
root@ReadyNAS:~# ps aux | grep "btrfs" root 1158 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-worker] root 1182 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-worker-hi] root 1189 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-delalloc] root 1194 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-flush_del] root 1206 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-cache] root 1210 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-submit] root 1220 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-fixup] root 1225 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio] root 1236 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio-met] root 1244 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio-met] root 1249 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio-rai] root 1261 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio-rep] root 1274 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-rmw] root 1277 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-endio-wri] root 1286 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-freespace] root 1295 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-delayed-m] root 1302 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-readahead] root 1310 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-qgroup-re] root 1317 0.0 0.0 0 0 ? S< Sep24 0:00 [btrfs-extent-re] root 1828 0.0 0.0 0 0 ? S Sep24 0:00 [btrfs-cleaner] root 1829 0.1 0.0 0 0 ? D Sep24 1:35 [btrfs-transacti] root 14276 1.8 0.0 3204 8 ? D< Sep24 20:12 btrfs balance start -dusage 64 -musage 64 /data root 32204 0.0 0.3 4216 1924 pts/0 S+ 12:23 0:00 grep btrfs
root@ReadyNAS:~# btrfs balance status -v /data Balance on '/data' is running 102 out of about 33 chunks balanced (159 considered), -209% left Dumping filters: flags 0x7, state 0x1, force is off DATA (flags 0x2): balancing, usage=64 METADATA (flags 0x2): balancing, usage=64 SYSTEM (flags 0x2): balancing, usage=64
- mdgm-ntgrSep 25, 2016NETGEAR Employee Retired
That's not normal.
Can you provide your logs (see the Sending Logs link in my sig)?
