Laserbait
Aug 16, 2016Luminary
Balancing takes weeks to complete
My RN204 running 6.05.01 with 3x 4TB and 1 2TB disk was running at about 80+% full between data and snapshots (even though I was only using about 4 TB for my data). I tried to do a balance, and aft...
mdgm-ntgr
Aug 16, 2016NETGEAR Employee Retired
Running it every day is way more than enough and unnecessary. Once a week at most should be sufficient.
If you never run a balance the filesystem may become quite unbalanced and the first subsequence balance may take a long time especially if the volume is quite full and the space is nearly fully allocated
Aug 16, 2016Guru - Experienced User
Agreed. I run it once a quarter, and it completes pretty quickly (the last one completed in 30 minutes). Perhaps start with once a week, and then try once a month and see if the completion time stays low.
- LaserbaitAug 16, 2016Luminary
I was doing the balance every month, but I have a lot of change data going to the RN204 (daily backups from my computers using Veeam with a 5 day retention), so in my case, I think the balance needs to be done more.
- JennCAug 18, 2016NETGEAR Employee Retired
Hello Lasebait,
You might want to see this article too: ReadyNAS OS 6: An overview of relevant scheduled maintenance tasks available
- JohnRoAug 22, 2016NETGEAR Employee Retired
Hi Laserbait,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- LaserbaitAug 24, 2016Luminary
Unfortunately, I have not had a chance to really see, as my RN20400 died shortly after this.
