rebop
Mar 18, 2013Tutor
Beeeping plus - please advise quickly
Hi folks, ReadyNas Duo. All has been fine, but just started beeping. Once - a few seconds later and again. A little later three times, etc. I checked Raidar and Raidiator and all shows fine. Temps....
rebop
Mar 19, 2013Tutor
Thanks again Stephen.
So, I think I have to live with the backup I have. I think I would have time to backup the configuration (can you point me to where so I can get there quickly?).
Then, if I am understanding, remove one drive when fully powered to see if it stops the beeping. If it does not, reinsert that drive and sync? What is it fails there? Can I just power down knowing the beeping drive is in the device now. Remove it. Insert the good drive and power up and go get another drive insert and sync? This is where I get a bit confused and really want to be clear. And does the new drive need to be identical? May not be still available. And if not, then do I need two new drives?
Sorry for so many questions but I am just a little confused and want to minimize the risk of losing everything if possible.
Thanks again.
~Bob
Thanks again.
~Bob
