rebop
Mar 18, 2013Tutor
Beeeping plus - please advise quickly
Hi folks, ReadyNas Duo. All has been fine, but just started beeping. Once - a few seconds later and again. A little later three times, etc. I checked Raidar and Raidiator and all shows fine. Temps....
rebop
Mar 19, 2013Tutor
OK, once again your reply sincerely appreciated.
I did find a backup called _READYNAS_CONFIG-Nasbox-20121113-193623. So I think that is good.
So all of this is done hot.
Try to determine which drive beeps.
If I can, remove that drive
If beep stops, then insert new drive and sync (or run on 1 drive until I can get a new drive?)
If desired, after sync, remove the good old drive and replace with new model drive and sync
OR
Remove drive and beep continues
Insert other drive and wait for resync and hope nothing fails during resync (?? yes?)
Then remove bad drive
insert new
sync
remove old if I choose
insert second new drive
resync
Yes?
And is there a general agreement WDC red? Anything better?
Thanks Stephen.
~Bob
OR
insert new
sync
resync
Yes?
Thanks Stephen.
~Bob
