rebop
Mar 18, 2013Tutor
Beeeping plus - please advise quickly
Hi folks, ReadyNas Duo. All has been fine, but just started beeping. Once - a few seconds later and again. A little later three times, etc. I checked Raidar and Raidiator and all shows fine. Temps....
Mar 19, 2013Guru - Experienced User
Assuming you don't drop them, or something the drives should be usable. The worst case would be that you'd somehow end up with "corrupt root", which you can fix via a factory reset (or by deleting the volumes manually on a PC).
rebop wrote: BTW, is there anything I could do in this process to make the new drives unusable? I would hope that at worst I could install the two new drives and copy over everything from that external USB drive an be back to normal. But if not, please advise
