rebop
Mar 18, 2013Tutor
Beeeping plus - please advise quickly
Hi folks, ReadyNas Duo. All has been fine, but just started beeping. Once - a few seconds later and again. A little later three times, etc. I checked Raidar and Raidiator and all shows fine. Temps....
rebop
Mar 19, 2013Tutor
OK. Thanks.
So, Stephen,. would you just check my previous post for accuracy and if I'm good, I'll be off after work today to buy drives.
I think my biggest concern at the moment is pulling the wrong drive and having something fail while resyncing as I recall that can take hours to do. So I guess I need to ask the question if I do pull the wrong drive, can I shut down, take out the bad and put in the good and function as a single drive until I get the new drive in to sync? Or does that create havoc?
Thanks.
Thanks.
