rebop
Mar 18, 2013Tutor
Beeeping plus - please advise quickly
Hi folks, ReadyNas Duo. All has been fine, but just started beeping. Once - a few seconds later and again. A little later three times, etc. I checked Raidar and Raidiator and all shows fine. Temps....
Mar 19, 2013Guru - Experienced User
The post looks good. I haven't tried pulling a drive, then powering down, reinserting the pulled drive, and powering up.
You seem very concerned about losing data. Maybe while you are shopping you could look for a SATA/USB adapter (with power supply) or a USB shell. Then you could test for the beep using a Windows PC, with the NAS safely shut down. With the right software tools you can also pull the data off the first hard drive.
