rebop
Mar 18, 2013Tutor
Beeeping plus - please advise quickly
Hi folks, ReadyNas Duo. All has been fine, but just started beeping. Once - a few seconds later and again. A little later three times, etc. I checked Raidar and Raidiator and all shows fine. Temps....
Mar 20, 2013Guru - Experienced User
Some people have trouble booting up on the second disk (the xraid parity volume). Though I don't see much risk with your method, as along as you keep the drives in their original slots.
Hot-swapping is best (in my experience) if you are wanting/needing to resync. Power-down is best (and really the only way) to avoid resync.
What PCs do you have? I'm still wondering if off-line troubleshooting is an option for you.
