rebop
Mar 18, 2013Tutor
Beeeping plus - please advise quickly
Hi folks, ReadyNas Duo. All has been fine, but just started beeping. Once - a few seconds later and again. A little later three times, etc. I checked Raidar and Raidiator and all shows fine. Temps....
rebop
Mar 20, 2013Tutor
Oops. W530
So, now a bit confused. If I go with the hot swap and pull the wrong drive, then I have to reinsert it and hope the bad drive does not fail before resync occurs? If I get lucky, I pull the failing drive, replace with new and resync and all good. Then pull the older drive, replace with new and resync and done. But if I make the wrong choice I stand to have issues.
What do you recommend I try Stephen?
Off to go buy two drives finally.
~bob
~bob
