rebop
Mar 18, 2013Tutor
Beeeping plus - please advise quickly
Hi folks, ReadyNas Duo. All has been fine, but just started beeping. Once - a few seconds later and again. A little later three times, etc. I checked Raidar and Raidiator and all shows fine. Temps....
Mar 24, 2013Guru - Experienced User
Yes, the Reds are cooler (because they use less power).
Sounds like you are all set. After everything resyncs, you might want to do a complete backup.
