LDI
Sep 24, 2014Aspirant
Best way backuping WS2008 to off site
Hi, I need help to know what is the best way to backup a WS2008 to a Readynas (312) that is off site. Is there any solution with readycloud?? I need to backup it by bloc cause I've some database. ...
garyd9
Sep 25, 2014Virtuoso
Does the database server have any mechanism for WAN replication built in? Usually, that would be the best choice. (Some type of journal-based replication is usually used.)
If it doesn't have any type of built in mechanism, and doesn't keep a journal you can replicate, then you're going to have a very hard time finding ANY real-time replication solution that could ensure a non-corrupted database copy.
Knowing a bit more about the source database would be helpful. Some databases could probably be coaxed into directly replicating to a WAN server. For example, I believe modern mysql supports WAN replication, and a mysql server could also be installed on a readynas device...
