redstamp
Jan 20, 2018Apprentice
Best way to get DDNS for DtDNS.com on RN104
I have tried a number of dynamic dns providers (dtdns, dyndns, no-ip) and have found dtdns to be the most reliable and best service. OK the website is out of date, but like most things its doesn't l...
- Mar 19, 2018
Sincere apologies to anyone who tried my solution - I just spent a few hours diagnosing why my second NAS wasn't updating and eventually found a daft error... the ddclient.conf file should start with use=web and not user=web as I wrote in the initial solution - otherwise everything is as-is.
Jan 20, 2018Guru - Experienced User
You could just try the DDClient app (it should be in available apps, and it also can be downloaded from http://apps.readynas.com/pages/?page_id=9 and manually installed). I don't know if it will work with DtDNS or not.
FWIW, my older R8500 router and my current RBR40 Orbi support both no-ip and dyndns (but not DtDNS). I've switched to no-ip some time ago (when dyndns dropped their free service), and have had no issues with it.
You might consider also using no-ip.com in the 4XS router, since there is no downside to using both services.
redstamp
Well that wasn't simple but finally got it working and thought I'd post how to help others...
I did try the DDClient that comes with the NAS apps, but it gets complicated. As per this post (https://community.netgear.com/t5/Using-your-ReadyNAS/ddclient-seting-up-readynas-104-missing-ddclient-conf-file/m-p/1019730#M100107), the install recommends editing the ddclient.conf file in the DDClient share. This issue is this is a link to a file retained in the /etc folder. Although the ddclient link in the NAS share has all file permissions enabled, it doesn't help, as the 'real' file in the /etc folder has only -rw------, which means you have to Putty into the NAS under SSH and logged in as root to be able to edit it!
This effecetively means enabling SSH and for password authentication and enabling shell access for admin (I think) - at least that was the only way I managed it - which means you have to remember to close it all down again after you're done.
So once you have opened the terminal window and logged in as 'root' using your admin user password, navigate to /etc using 'cd /etc' and just check you can see the ddclient.conf file using 'ls -la'.
Now you have to learn the linux editor 'vi' to be able to edit the ddclient.conf file in the Putty terminal window. Lots of You Tube video tutorials, but its a real pain initially as all of your normal ways of editing in Windows are useless. Basically learn how to put 'vi' editor into command and edit mode and learn the necessary shortcuts to exit, save, delete lines etc.
There is a good list of different configs for different DDNS providers here (https://sourceforge.net/p/ddclient/git/ci/60fe051b7a504573386e2df2ffa8703dd47a8cb9/tree/sample-etc_ddclient.conf) and mine almost worked first time, except it didn't. Using the config directions from this page I swapped all of the config in the ddclient.conf file for:
protocol=dtdns
server=www.dtdns.com
client=ddclient
password=mypassword
mydomainwithdtns.com
NB note the fact you don't need your username!
Eventually I tried a few things and finally after adding 'use=web' to tell the ddclient where to get the IP address from to upload to DtDNS, it seems to work - yay!!
So my ddclient.conf file now reads:
use=web
protocol=dtdns
client=ddclient
password=mypassword
Save, exit vi editor, close putty, restart DDClient app in the NAS and you should be done! If you find this difficult to follow, then don't bother, as I have written it for a newbie linux user like myself to follow... any less proficient and you probably risk leaving your NAS open or vunerable. Obviously those with more knowledge will find this overly simple, but hopefully will help anyway.
- JohnCM_SJan 20, 2018NETGEAR Employee Retired
Hi redstamp,
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
JohnCM_S
NETGEAR Community Team - StephenBJan 20, 2018Guru - Experienced User
I'm glad you managed to get it working.
One alternative to vi -
you can copy the file from /etc to a NAS share from ssh. Then edit it from windows using Notepad++ and keeping in it linux format. When done, copy it back to /etc. Note this won't work with notepad.
- redstampMar 19, 2018Apprentice
- StephenBMar 19, 2018Guru - Experienced User
I took the liberty of editing your earlier post, so it now starts with use=web
