redstamp
Jan 20, 2018Apprentice
Best way to get DDNS for DtDNS.com on RN104
I have tried a number of dynamic dns providers (dtdns, dyndns, no-ip) and have found dtdns to be the most reliable and best service. OK the website is out of date, but like most things its doesn't l...
- Mar 19, 2018
Sincere apologies to anyone who tried my solution - I just spent a few hours diagnosing why my second NAS wasn't updating and eventually found a daft error... the ddclient.conf file should start with use=web and not user=web as I wrote in the initial solution - otherwise everything is as-is.
Jan 20, 2018Guru - Experienced User
I'm glad you managed to get it working.
One alternative to vi -
you can copy the file from /etc to a NAS share from ssh. Then edit it from windows using Notepad++ and keeping in it linux format. When done, copy it back to /etc. Note this won't work with notepad.
redstamp
Mar 19, 2018Apprentice
- StephenBMar 19, 2018Guru - Experienced User
I took the liberty of editing your earlier post, so it now starts with use=web
