MattNeimeyer
Aug 08, 2016Guide
Best way to move 7tb of files internal to the NAS?
So I just set up Amazon Cloud Drive on my ReadyNas Ultra 6 running 6.5.1 (final release) and it works fine. I just want to move over all my files from "OldShare" into the newly created AmazonCloudDri...
MattNeimeyer
Aug 08, 2016Guide
I'm confused... as I read the docs --reflink=auto is just a standard copy... isn't that going to double the storage requirements prior to the rm step?
I've only got 2Tb free and 7Tb to move...
Sorry if I'm missing something.
mdgm-ntgr
Aug 08, 2016NETGEAR Employee Retired
It speeds up the copy but you still need a little space, but not much (see StephenB's post below). Really though you should keep plenty of free space available on the volume so typically this shouldn't be a problem.
- StephenBAug 09, 2016Guru - Experienced User
If the reflink works, there shouldn't be an space increase (at least not much - metadata will increase some).
--reflink=always might be better than auto, it will return an error if the reflink isn't possible.
