konsum69
Feb 14, 2018Aspirant
Betreff: WD60EFRX in ReadyNAS Duo V2 (arm) firmware 5.3.13 working
tested HDD WD60EFRX in ReadyNAS Duo V2 (arm) working WD60EFRX-68L0BN1 firmware 82.00A82 RAIDiator 5.3.13 HDD in X-Raid2 formatted, transfer rates with large (several 100MB) files 35-40 MB/sec in g...
konsum69
Feb 17, 2018Aspirant
Now I added a second WD60EFRX to the first one and had to see disappointed that the firmware will do the following if you make a factory reset via paper clip and pushing twice the backup button and using the paper clip again:
- if you select X-RAID2: it will create a Raid1 in X-RAID2 over both physical drives (which is according to the manual)
- if you select Flex-RAID and then Raid0 or JBOD: it will always create a Raid1 in Flex-RAID over both physical drives (which is not according to the manual)
But I would like to use the full 12 TB (2x 6TB) in one logical volume for data because I have another NAS for backing up the data. So I need no mirroring. Is there another possibility to force the device to do this? Via console?
What I will try out now is: only one WD60 in the NAS and then adding the second after the system has created one logical volume in Flex-Raid mode on the first physical drive. I think the system then will create another logical volume in Flex-Raid mode on the second physical volume WD60. I think I saw it before.
In X-RAID mode adding the second WD60 will lead in a Raid1 in X-RAID mode (according the software manual). So this will not help.
has anybody an idea?
- konsum69Feb 17, 2018Aspirant
The configuration in the last post was done with Raidar 6.3.0. I think this version is faulty!
Because with the old version of Raidar 4.3.8 the configuration was good: selected Flex-RAID with Raid0 and now one logical volume over 10,9 TB with two physical WD60EFRX!
