nsne
Oct 03, 2016Virtuoso
Bizarre Behavior: Data Missing, Shares Inaccessible
This morning my wife and I opened our laptops (MacOS Sierra; mine's running the Public Beta) and found that our machines wouldn't connect to our Time Machine backups on the ReadyNAS. Something along ...
mdgm-ntgr
Oct 03, 2016NETGEAR Employee Retired
Send the logs zip in (see the Sending Logs link in my sig).
nsne
Sent.
- mdgm-ntgrOct 03, 2016NETGEAR Employee Retired
It seems you have quite a few apps installed. Which apps do you have installed?
Are any of the ones you have installed incompatible with 6.6.0?: Community app compatibility with ReadyNAS OS 6.6.0- nsneOct 03, 2016Virtuoso
I've got Plex and Logitech Media Server installed. Neither was listed as incompatible with 6.6.0.
I can see PHP, Transmission, syslog, btsync etc. are on the system.
The logs indicate that some permissions are set incorrectly.
Do you have a backup?
