nsne
Oct 03, 2016Virtuoso
Bizarre Behavior: Data Missing, Shares Inaccessible
This morning my wife and I opened our laptops (MacOS Sierra; mine's running the Public Beta) and found that our machines wouldn't connect to our Time Machine backups on the ReadyNAS. Something along ...
nsne
Sent.
mdgm-ntgr
Oct 03, 2016NETGEAR Employee Retired
It seems you have quite a few apps installed. Which apps do you have installed?
Are any of the ones you have installed incompatible with 6.6.0?: Community app compatibility with ReadyNAS OS 6.6.0
- nsneOct 03, 2016Virtuoso
I've got Plex and Logitech Media Server installed. Neither was listed as incompatible with 6.6.0.
- mdgm-ntgrOct 03, 2016NETGEAR Employee Retired
I can see PHP, Transmission, syslog, btsync etc. are on the system.
The logs indicate that some permissions are set incorrectly.
Do you have a backup?- nsneOct 03, 2016Virtuoso
I deleted Transmission ages ago. Forgot BTSync was on the system; it's been so long since I used it. Not sure why PHP or syslog would be there. I never knowingly installed either of them. They might have been residual files from other add-ons that I removed a long time ago.
I have most of the data backed up but not a full system backup.
