Thelostboy
Aug 25, 2018Aspirant
Blinking red LED after installing new HDD
Hi guys! Hopefully some one can help me out. Installed a new 6TB hdd yesterday with no issues, rebuilding & resyncing went fine, LED was flashing blue during this. Installed another 6TB today &...
Aug 26, 2018Guru - Experienced User
Do you know what which LED this is? The hardware manual might help, see pages 116-118 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Per the manual, it's normal for the disk LED to be red while the disk is being synced. You can download the log zip file, and look at the SMART stats in disk_info.log if you like.
Thelostboy
Aug 26, 2018Aspirant
Hello StephenB
Sorry should have been a bit clearer, it was the disc activity led.
I was under the impression a red led indicated a fault, as the disc I did prior was flashing blue when re-building/re-syncing.
But the volume has been re-built & re-synced with no issues. So all is good! Thanks for the info.
