JonasSamuelsson
Feb 27, 2014Aspirant
Boot problem.
After my Readynas NV+ boots it's not reachable. When I scan it I finds that ports 111,548,631,50000 are open,. It doesn't answer on http, ftp or cifs.
The display on the NAS shows the IPaddress and the disk LEDs are green. Any clues anyone?
- mdgm-ntgrNETGEAR Employee RetiredWhat do you see in the Info (far right) column in RAIDar?
- JonasSamuelssonAspirantVersion 4:1:13
- mdgm-ntgrNETGEAR Employee RetiredTry an OS Re-install
- JonasSamuelssonAspirantWont that delete the files on the Nas?
- mdgm-ntgrNETGEAR Employee RetiredNo, I suggested an OS Re-install not a factory default
- JonasSamuelssonAspirantOk. Found it. I will try it. Thanks.
- JonasSamuelssonAspirantIt worked. Thank you.
