colmosiris
Feb 18, 2016Aspirant
Browser and Finder access problems
Model: ReadyNAS NV+ - tried typing it in, but it wasn't accepted. Computer: Mac Mini, OS: OS 10.9.5. Three User accounts on the machine: 'Admin' (the only one with admin privileges), 'Username',...
Feb 18, 2016Guru - Experienced User
Do you remember the admin password?
What firmware is running on the NAS (RAIDar can tell you even if you can't log in). If the firmware is very old you might have a browser compatibility issue.
- JennCFeb 18, 2016NETGEAR Employee Retired
Hello colmosiris,
If you are trying to access the admin page, "admin" user account is the only account that should be able to get in. As StephenB mentioned, it could be a browser compatibility issue, try using an older one like IE9.
Knowing the FW version is also important, if NAS is running a 5.3.x then you have an RND4000v2 (ReadyNAS NV+ v2), if it is a 4.1.x then that is RND4000v1 (ReadyNAS NV+ v1.
See these two articles that may help recover the password:
I lost the administrator password for my Duo v2 or NV+ v2; how can I recover it?
** the last article works with Duo v1 and NV+ v1 too
- colmosirisFeb 18, 2016Aspirant
Thanks very much for getting back to me so quickly.
Yes, the password is held for me in Dashlane. It's a random string.
Ah yes, that could well be the browser issue. The firmware is 4.1.8. On the newer box I have, it's 5.3.8. Should they be the same? If so, how do I update it, please?
This won't solve the issue of not being able to access it in the Finder in other accounts though. I'd assumed what I had was two different aspects of the same problem, but they could well be two unrelated problems!
Cheers
Thanks Jen. I think I may have not made clear that the 'Admin' account I'm talking about is the Mac's User account, and not the 'admin' username for the NAS box.
I do know the password. It just doesn't work! The only place it does work is in the Finder in one of the User Accounts, but not in the others, and not in the browser in any account. By contrast, my ReadyNAS NV+ V2 box works fine in both browser and Finder on all User accounts, and the password is saved in the keychain, as well as in Dashlane.
Cheers
Sorry, JennC, I misspelled your name. :(
