Joufflu
Oct 11, 2015Aspirant
btrfs-cleaner always stuck at 100% CPU after 6.4.0 upgrade
Hello, After 6.4.0 upgrade btrfs-cleaner process always uses 100% cpu even after many uptime hours. SMB shares are ok (but slow) Frontview times out after authentication. Top command (ssh i...
spotcatbug
Oct 12, 2015Apprentice
I'm also unable to use the NAS, although it appears to be fully booted. I just ssh'd in to check it out. Indeed, btrfs-cleaner is (apparently) hard at work.
In my case, if I wait for about 90 minutes after boot, the NAS becomes usable again. I suspect the btrfs-cleaner process will not be active at that point. I will confirm in about an hour (hopefully).
UPDATE: As suspected, when btrfs-cleaner stopped, the NAS became fully usable. Also, I did an immediate reboot to see if btrfs-cleaner would go wild again - it didn't. The NAS seems to be working normally for now.
