bartw
Jun 13, 2019Aspirant
BTRFS critical (device md0): corrupt leaf, unaligned key offset for file ...
Hi all, I have a very recent system installed at a customer and the RN424 was running fine (backup-NAS). Today I visited the customer and saw that Radiator reported "Management Service offline",...
JohnCM_S
Jun 13, 2019NETGEAR Employee Retired
Hi bartw,
'Management Service offline' means that readynasd is not running. The reason it is not running is because md0 has a corrupt operating system. md0 needs to run for readynasd to run.
You will need to get some assistance in fixing the operating system. You may contact NETGEAR support so they can assist you on that.
Alternatively, you can boot the NAS in Read-Only to make your data accessible. You can then backup your data and reset the NAS to factory default afterward.
- Jul 21, 2021Retired_Member
