bobba84
Apr 03, 2018Luminary
BUG in 6.9.3 FIRMWARE
Hi Netgear, Aside from my unresolved (for more than a year) issue (here), I would like to report a bug in the latest firmware. When the UPS check box under email alerts is unticked, I still r...
bobba84
Thanks mdgm,
I have done that. I disabled the check box on the same day I upgraded to 6.9.3, which was about 29th March from memory.
Bobby.
bobba84
Apr 05, 2018Luminary
Any news?
Thanks,
Bobby.
- bobba84Apr 10, 2018Luminary
mdgm, is there any news? This bug is persisting.
Thanks,
Bobby.
- mdgm-ntgrApr 10, 2018NETGEAR Employee Retired
I've reported the alerts still being sent even with the checkbox unchecked.
As for your the UPS connection issue that would suggest that there could be a problem with your UPS.- bobba84Apr 10, 2018Luminary
Thanks for the update. Hopefully the next verison is better.
As for my UPS, it doesn't have this issue when connected to anything else. At least if the above is sorted I won't get emails everyday :)
I appreciate your help.
Bobby.
