AddisonTech's avatar
Jan 13, 2016
R7000 Firmware Bug 1.0.6.28
The other night, I flashed the firmware, as the router notified me of an update to version 1.0.6.28_1.1.83.  After doing so, my wife's laptop will no longer connect to the home 2.4 GHz network; however it will connect to the guest network.  I also noticed the same behavior on my Galaxy S5, which, strangely enough, will connect to the 5G band, as it always has.  I even changed the passkey on the 2.4GHz home network and went so far as to make a slight change in the SSID, neither of which worked.  Thinking that there is a bug in that firmware, I downgraded to the old version: 1.0.5.48_1.1.79.  That solution did not solve the problem.  With my wife's laptop connected only to the guest network, she can no longer print to the wireless laser printer, nor can she access the NAS to view and store files.  I haven't yet performed a factory reset; however if that may be the only option, I can do that.
  • So far, so good.  I just flashed my R7000 and it even kept my modified IP settings, so I don't have to modify those parameters.  It appears to "see" the connected devices, and my Samsung printer works on the IP that was assigned.  If I notice any glitches, I'll post again.  Also, will Arlo be in the final version and off by default?
    Thank you.
