ZkiiFreak
Nov 28, 2014Aspirant
Burning ISO's directly to DVD's
Hi everybody I've attached my Samsung USB DVD burner to the front USB port on my RN314. Put in a blank recordable DVD. Installed growisofs by using apt-get in a shell session. (apt-get install gro...
ZkiiFreak
Nov 29, 2014Aspirant
StephenB wrote: Did you use df to determine the mount point of the DVD burner?
Nope.
But trying df gives the following result:
root@PIPPERNASV3:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 4190208 2392872 1457968 63% /
tmpfs 10240 4 10236 1% /dev
/dev/md0 4190208 2392872 1457968 63% /
tmpfs 1019036 44 1018992 1% /dev/shm
tmpfs 1019036 6884 1012152 1% /run
tmpfs 1019036 0 1019036 0% /sys/fs/cgroup
tmpfs 1019036 0 1019036 0% /media
/dev/md127 5845988352 2584807312 3257830512 45% /data
/dev/md127 5845988352 2584807312 3257830512 45% /home
/dev/md127 5845988352 2584807312 3257830512 45% /apps
/dev/md127 5845988352 2584807312 3257830512 45% /var/ftp/home
/dev/md127 5845988352 2584807312 3257830512 45% /var/ftp/Backup
/dev/md127 5845988352 2584807312 3257830512 45% /var/ftp/media
/dev/md127 5845988352 2584807312 3257830512 45% /var/ftp/Music
/dev/md127 5845988352 2584807312 3257830512 45% /var/ftp/Pictures
/dev/md127 5845988352 2584807312 3257830512 45% /var/ftp/Videos
/dev/md127 5845988352 2584807312 3257830512 45% /run/nfs4/data/Backup
/dev/md127 5845988352 2584807312 3257830512 45% /run/nfs4/data/media
/dev/md127 5845988352 2584807312 3257830512 45% /run/nfs4/data/Music
/dev/md127 5845988352 2584807312 3257830512 45% /run/nfs4/data/Pictures
/dev/md127 5845988352 2584807312 3257830512 45% /run/nfs4/data/Videos
tmpfs 4 0 4 0% /data/Videos/snapshot
tmpfs 4 0 4 0% /run/nfs4/data/Videos/snapshot
tmpfs 4 0 4 0% /var/ftp/Videos/snapshot
Does not give me the USB DVD drive though ?!? At this moment, there is no blank disc in the drive. Does that make a difference?
Output from lsusb:
root@PIPPERNASV3:~# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) 64MB QDI U2 DISK
Bus 001 Device 006: ID 0e8d:1956 MediaTek Inc.
Any takes on how to get the mount point then?
Thanks.
