ZkiiFreak
Nov 28, 2014Aspirant
Burning ISO's directly to DVD's
Hi everybody I've attached my Samsung USB DVD burner to the front USB port on my RN314. Put in a blank recordable DVD. Installed growisofs by using apt-get in a shell session. (apt-get install gro...
ZkiiFreak
Nov 29, 2014Aspirant
Thanks
But I do not seem to get it. According to the post you are referring to, I should have a /dev/dvd-rw file (or something similar). I don't:
Am I missing something?
Maybe it might be because the Samsung USB drive actually is a BD drive as well? It DOES have the ability to write DVD's...
root@PIPPERNASV3:/dev# ls
autofs cpu kmsg loop7 mptctl rtc sdb3 sg0 stdout tty14 tty22 tty30 tty39 tty47 tty55 tty63 vcs vcsa2
block cpu_dma_latency log mapper net rtc0 sdc sg1 tgt tty15 tty23 tty31 tty4 tty48 tty56 tty7 vcs1 vcsa3
boot_reason disk loop0 mcelog network_latency sda sdc1 sg2 tty tty16 tty24 tty32 tty40 tty49 tty57 tty8 vcs2 vcsa4
bsg fd loop1 md network_throughput sda1 sdc2 sg3 tty0 tty17 tty25 tty33 tty41 tty5 tty58 tty9 vcs3 vcsa5
btrfs-control full loop2 md0 null sda2 sdc3 sg4 tty1 tty18 tty26 tty34 tty42 tty50 tty59 ttyS0 vcs4 vcsa6
bus fuse loop3 md1 port sda3 sdd shm tty10 tty19 tty27 tty35 tty43 tty51 tty6 ttyS1 vcs5 vpd
char i2c-0 loop4 md127 ptmx sdb sdd1 snd tty11 tty2 tty28 tty36 tty44 tty52 tty60 ttyS2 vcs6 zero
console initctl loop5 mem pts sdb1 sdd2 stderr tty12 tty20 tty29 tty37 tty45 tty53 tty61 ttyS3 vcsa
core input loop6 mpt2ctl random sdb2 sdd3 stdin tty13 tty21 tty3 tty38 tty46 tty54 tty62 urandom vcsa1
