jaime1
May 07, 2012Aspirant
Business nas cpu specifications
I'm looking at the business nas specs, but the list only has intel core, is there a list of the specific cpus these use? I'm looking at the nvx, pro 4, and 6. Thanks.
mdgm-ntgr
May 07, 2012NETGEAR Employee Retired
Would recommend avoiding buying the NVX unless you are on a tight budget and can find the NVX for considerably less than the Pro 4.
The Pro 6 is the fastest desktop ReadyNAS by a long way and a great choice if budget permits. I particularly like the optional dual-redundancy on the 6-bay models.
