Deeperdown
Mar 12, 2021Tutor
C Drive Failure/Faulty Drives
Hi All, This evening my NV+ stopped working which was noted by the TV saying "no contect". Upon investigation, i identified that the NV+ had locked up in that it was still on, powered and showing "...
Mar 12, 2021Guru - Experienced User
Try testing the drives in a Windows PC with vendor tools (Seatools for Seagate; Lifeguard for Western Digital).
You can connect the drives with with SATA or with a USB adapter/dock.
If you actually have 2 failed drives (which is certainly possible), then data recovery will not be easy. There are companies that specialize in it, but it will be expensive.
Deeperdown
Mar 12, 2021Tutor
Thanks I’ll give it a try-can you suggest a usb version
