janpeter1
Oct 17, 2016Luminary
Camera import function OS 6.5 on
Hi, I have used ReadyNAS 314 for about a year now and works fine. The last few days I have started to use the Backup/Import function where you can specify where photos from a camera should ...
ajahearn
Mar 19, 2017Aspirant
I have a similar issue but I am also finding that the device only copies files with a .jpg extension whereas most of my photos are stored in the Nikon RAW (NEF) format. It would be very useful if I could connect up the camera, have it look for any new files, and back those up in the same organization as the memory card.
- FramerVMar 27, 2017NETGEAR Employee Retired
Hi janpeter1,
This could be a good addition to our Idea Exchange for ReadyNAS.
If in case you have not posted this yet, please do so.
I will also be inquiring about your case as well.
