Benny2019
Jan 09, 2019Aspirant
Camera Magic
I recently purchased a RN42400 primarly for video surveillance. The product shows thousands of compatible cameras but on close inspection, most, if not all, of the cameras listed are no longer manufa...
Benny2019
Jan 21, 2019Aspirant
Thank you for your information John. I purchased the unit in the middle of December 2018 and bought licenses for cameras at the same time. It is very disappointing to find that something I just purchased is no longer supported. It is even more troubling that ReadyNas would not respond to a support case that I opened on the product.
I looked at Milestone Arcus' website and it does not look like ReadyNas Surveillance at all. It seems that today some of the ReadyNas Surveillance information has been taken offline and links on the website now point to removed pages. The Smart Video Surveillance Solutions for Small, Medium and Enterprise PDF is still live and talks about ReadyNas Surveillance (https://www.netgear.com/images/pdf/Smart-Video-Surveillance-Solutions-Small-Medium-Enterprises.pdf) .
What I have found through trial and error is that if I connect to the ReadyNas using Internet Explorer (I prefer to use Chrome or Firefox) that I can almost connect to a camera. I've found that IE is required but I must first use one of the cameras on the list inside the application and ignore the camera compatibility list that includes thousands of cameras that are no longer available. When I try to connect to the camera through the ReadyNas Surveillance application IE downloaded the Windows C++ and several other runtimes. However, the application still crashes when it tries to execute the application to view the video stream from the camera. It looks like a PHP or JAVA application and the problem might be because Java is not installed on the computer.
Sandshark
Jan 21, 2019Sensei
I think you have an issue with whoever sold you those licenses. I don't believe they were still valid (which could explain Netgear not responding). How Netgear let resellers know that and how they were compensated if they had "inventory" when ReadyNAS Surveillance was discontinued, I have no idea.
FWIW, I think running a surveillance program on a headless device like a NAS is a really bad idea.
