abshapi's avatar
abshapi
M4250 - Black Magic
Hey All,
First time posting here.   Here is my situation that I could use some help with.
I purchased and installed some Netgear M4250 switches throughout my venue.   Using the Engage software, I've setup a few VLAN's with them, Lighting, Audio, Video, etc.  Each of these VLAN's have a DHCP server from one switch.  The system I setup is isolated from the internet on purpose as I want to maintain minimal network traffic over the system.
I'm looking now to get a Black Magic Web Presenter into the video network.  This device has one network port that is designed to both handle the setup/control of it and additionally, push video to the internet.   Putting this device on the network I setup however doesn't work because I don't have internet on the network.
On my video switch I want to be able to have the following 3 ports.
Port 1) connects to the rest of my network with an AutoTrunk while utilizing the Video VLAN with it' own DHCP Server.
Port 2) connect to another network I have in my building that provides internet.  This network has its own DHCP Server.
Port 3) my Web Presenter that takes traffic from both Port 1 and Port 2.   IP Address of the device would live in the range that comes from Port 1.
How would I configure this in the M4250.
  • schumaku's avatar
    schumaku
    The Blackmagic Web Presenter (HD or 4K does not matter) get the video input from an SDI. To be workable, the Ethernet port must be connected to a VLAN with an IP subnet able to reach the Internet. This can be achieved by configuring a dedicated VLAN connecting to the as you have already started with the port 2 and port 3 connection idea. Just access port config is sufficient for 2 and 3 There it goes the illusion having a fully isolated environment. Alternatively, consider a direct Ethernet link for the BMD Video Presenter to the building network with Internet access.
    • abshapi's avatar
      abshapi
      What I don't understand how to setup is the VLAN with the internet access being able to talk with the web presenter if it is in a different VLAN with a DHCP server feeding it an address.   How do I setup a single port on the M4250 to effectively function as a router; bridge two different networks?   Thats the crux of my issue.   I don't imagine it's in the AV GUI, I'd have to go into the main GUI, but where?
  • I purchased and installed some Netgear M4250 switches throughout my venue. Using the Engage software, I've set up a few VLANs with them, Lighting, Audio, Video, etc. Each of these VLANs has a DHCP server from one switch. The system I set up is isolated from the internet on purpose as I want to maintain minimal network traffic over the system. I'm looking now to get a Black Magic Web Presenter into the video network. This device has one network port that is designed to both handle the setup/control of it and additionally, push video to the internet. Putting this device on the network I setup however doesn't work because I don't have internet on the network. magical playground Pasadena Yelp
    • LaurentMa's avatar
      LaurentMa
      NETGEAR Expert
      Thank you Magicalkatrina  for using the NETGEAR AV Line switches and the NETGEAR Engage controller in this installation!
      You will find the information about inter-VLAN routing and internet propagation from an external internet gateway you need here:
      https://www.netgear.com/hub/business/av/av-tech-guides/
      I think you should consult and follow the step-by-step instructions there (app note called “Configuring VLAN Routing Using Engage”): << We will go over how to create the routes on the firewall to point back to the core switch so that the VLANs will have Internet access. >>
      Any additional help, don't hesitate to email [email protected]
ProSupport for Business
