abshapi
Jun 29, 2023Aspirant
M4250 - Black Magic
Hey All, First time posting here. Here is my situation that I could use some help with. I purchased and installed some Netgear M4250 switches throughout my venue. Using the Engage softwa...
Magicalkatrina
Jan 05, 2024Aspirant
I purchased and installed some Netgear M4250 switches throughout my venue. Using the Engage software, I've set up a few VLANs with them, Lighting, Audio, Video, etc. Each of these VLANs has a DHCP server from one switch. The system I set up is isolated from the internet on purpose as I want to maintain minimal network traffic over the system. I'm looking now to get a Black Magic Web Presenter into the video network. This device has one network port that is designed to both handle the setup/control of it and additionally, push video to the internet. Putting this device on the network I setup however doesn't work because I don't have internet on the network. magical playground Pasadena Yelp
- LaurentMaJan 05, 2024NETGEAR Expert
Thank you Magicalkatrina for using the NETGEAR AV Line switches and the NETGEAR Engage controller in this installation!
You will find the information about inter-VLAN routing and internet propagation from an external internet gateway you need here:
https://www.netgear.com/hub/business/av/av-tech-guides/
I think you should consult and follow the step-by-step instructions there (app note called “Configuring VLAN Routing Using Engage”): << We will go over how to create the routes on the firewall to point back to the core switch so that the VLANs will have Internet access. >>
Any additional help, don't hesitate to email [email protected]
