abshapi
Jun 29, 2023Aspirant
M4250 - Black Magic
Hey All, First time posting here. Here is my situation that I could use some help with. I purchased and installed some Netgear M4250 switches throughout my venue. Using the Engage softwa...
Magicalkatrina
Jan 05, 2024Aspirant
I purchased and installed some Netgear M4250 switches throughout my venue. Using the Engage software, I've set up a few VLANs with them, Lighting, Audio, Video, etc. Each of these VLANs has a DHCP server from one switch. The system I set up is isolated from the internet on purpose as I want to maintain minimal network traffic over the system. I'm looking now to get a Black Magic Web Presenter into the video network. This device has one network port that is designed to both handle the setup/control of it and additionally, push video to the internet. Putting this device on the network I setup however doesn't work because I don't have internet on the network. magical playground Pasadena Yelp
LaurentMa
Jan 05, 2024NETGEAR Expert
Thank you Magicalkatrina for using the NETGEAR AV Line switches and the NETGEAR Engage controller in this installation!
You will find the information about inter-VLAN routing and internet propagation from an external internet gateway you need here:
https://www.netgear.com/hub/business/av/av-tech-guides/
I think you should consult and follow the step-by-step instructions there (app note called “Configuring VLAN Routing Using Engage”): << We will go over how to create the routes on the firewall to point back to the core switch so that the VLANs will have Internet access. >>
Any additional help, don't hesitate to email [email protected]
