crash0099
Apr 26, 2016Follower
Can I use ReadyNas as a hard drive for my lightroom 6?
I have a computer I built with running Windows 10 PRO. I only have a 240GB SSD for my hard drive. What I want know is can I also use the RN204 for my Network backup and also use it to work from Lig...
mdgm-ntgr
Apr 26, 2016NETGEAR Employee Retired
Was that old WD backup drive a USB disk?
The NAS is not a USB peripheral and you can't use it as such.
Does Lightroom work with network drives? If not, you will need to consider using iSCSI. I would recommend connecting your PC to your network using ethernet if you want to use iSCSI.
