Andy_L's avatar
Andy_L
Can no longer get to web interface after firmware update 6.5.2
Hi all, I’ve owned a ReadyNAS 102 since 2015 but not used it for quite some time. This week I’ve powered it back on and it was using firmware version 6.2.4 (I think). I backed up the data to an exte...
  • StephenB's avatar
    Nov 11, 2020
    "Corrupt Root" normally just means that the system can't boot from the OS partition on the disks.  It's unusual to see that error with the disks removed.
    Try connecting the disk to a PC, and either zero it with vendor tooks (seagate or lifeguard), or remove the partitions with (windows disk manager will do this if you are running windows).  Then reinsert the disk (with the NAS powered down), and then turn it on.  The NAS should do a fresh factory install.
