Andrew211
Aug 31, 2016Aspirant
Can not discover ReadyNas Device for use with ReadyCloud
Hey, Have been using ReadyCloud for a while with the ReadyNas device set up in the home office, worked a treat. Recently moved the device to a new location inside a large corporate network an...
JennC
Aug 31, 2016NETGEAR Employee Retired
Hello Andrew211,
ReadyCloud needs Internet connection as it connects to a server to validate the login details before it allows each user to access the NAS volume. If this is just for local access, you can just need to create each user's login and set permission to the shares..
Andrew211
Hey,
Yes would be a concern if I didn't know that :-)
Thanks for the reply, it jogged my memory that devices on this network need to have their MAC address registered, even though it's part of our private network, thanks!
