NickKhutorn
Dec 04, 2022Aspirant
Can not login default admin
Hello. ReadyNAS 314/.. My problem. After default reset cann't login as an admin. Trying admin - /password/1234/admin ...other Previous pass doesn't work. The defaults installed, its works..but i ...
- Dec 05, 2022
took off all hard's and format them.
Placed again, then RN get in safe mod, where I get whith standart pass
Now its resync data/
Dont know what will be after rebooting///10h
NickKhutorn
NickKhutorn
FW: V6.1.6
- StephenBDec 04, 2022Guru - Experienced User
NickKhutorn wrote:
FW: V6.1.6
Wow, very ancient (Feb 2014). Definitely should be upgraded.
I suggest trying another OS reinstall.
- NickKhutornDec 05, 2022Aspirant
How i can do it without nas web interface?
- StephenBDec 05, 2022Guru - Experienced User
See pages 74-75 of the hardware manual:
Be careful to do the OS reinstall (and not the factory default).
This will
- reset the admin password back to password
- reset the network configuration to use DHCP with no bonding
- turn off volume quota (which can be turned on again from the volume settings wheel)
sorry, 6.10.8
NickKhutorn wrote:
sorry, 6.10.8
So current, which is good.
The OS reinstall procedure is the same though.
