SH_Gabe
May 06, 2021Aspirant
Cannot connect Netgear NAS RN214 during USB Recovery
Hi, Due to the NAS failed to boot, I tried to do USB recovery. I followed the instruction in the link below. https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-...
Sandshark
May 06, 2021Sensei
That's because you have to TELNET into it in that condition, not use a browser. But it tends to indicate that the USB recovery didn't work completely. Since it seems to have done something, maybe just try again with the same USB. If that doesn't work, try re-creating it and try recovery again I recently had a NAS take 5 tries with the same USB I've used on others before it worked right. Figuring something had happened to the USB content, I re-created it after the second try, and it still took 3 more (without re-creating yet again) to work right.
mdgm
May 07, 2021Virtuoso
It can be something as simple as not putting the firmware image on the USB key that can lead to it falling into a debug mode.
You didn't state as to whether you'd done any other troubleshooting e.g. accessing the boot menu, seeing if it will boot into tech support mode etc.
The system failing to boot could be nothing to do with the internal flash in which case doing USB Boot Recovery is a waste of time.
There are other possibilities like a bad disk, full 4GB root volume etc.
- SH_GabeMay 10, 2021Aspirant
Thanks for your response.
I tried to access boot menu, but there was only option I can choose "Factory Default". However, I don't want to reset data.
So I am trying to do USB recovery now.
If the reason is bad disk, for example, one of the hard drive broke, how can I solve this?
Thanks,
- SandsharkMay 10, 2021Sensei
If the problem is on a drive, USB recovery will do nothing to help you. But at this point, you seem to have also have a "broken" boot menu. The only option available to you even before you tried the USB revovery was Factory Default? Not even Normal? If so, then the menu was already "broken" and maybe you did need USB recovery just to get to the next right step (likely OS re-install), but it may be that there is a problem with the flash memory in your NAS where that is stored. I still recommend you try again a couple times.
- SH_GabeMay 11, 2021Aspirant
Thanks for response.
Yes. Boot menu does not work with right options. There is only "Factory Default" on LCD and I cannot move to or select other menu such as "Normal" or "Disk Test" and so on.
I tried 10 times what you recommended, but it still not working...
