SH_Gabe
May 06, 2021Aspirant
Cannot connect Netgear NAS RN214 during USB Recovery
Hi, Due to the NAS failed to boot, I tried to do USB recovery. I followed the instruction in the link below. https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-...
Sandshark
May 06, 2021Sensei
That's because you have to TELNET into it in that condition, not use a browser. But it tends to indicate that the USB recovery didn't work completely. Since it seems to have done something, maybe just try again with the same USB. If that doesn't work, try re-creating it and try recovery again I recently had a NAS take 5 tries with the same USB I've used on others before it worked right. Figuring something had happened to the USB content, I re-created it after the second try, and it still took 3 more (without re-creating yet again) to work right.
SH_Gabe
May 10, 2021Aspirant
Thanks,
I am trying with your suggestion. I will update the result later.
