malcstatic
Oct 13, 2016Aspirant
Cannot connect RN104 to ReadyCloud
Hi There, I like a few other people on here, am having trouble connecting my ReadyNas to ReadyCloud. Can I send my LOGS to someone to have a look at please? I'm sure it's a very simple solution...
- Oct 13, 2016
Alright, so your account has not yet been migrated to a readycloud account, or you didn't bind the readycloud username to your myNetgear account.
There are two options, either you disconnect your NAS from the readycloud and then rejoin using your MyNetgear email as the username, OR you upgrade/bind your old readycloud account to your MyNetgear account by doing the following:
Go to readycloud.netgear.com, press "login" -> "Upgrade to a MyNetgear account" -> "Upgrade your existing ReadyCLOUD account". Then log in with your old username and password and follow the steps. I can't recall all steps exactly but it will eventually ask you for an email, and it will detect that it's already registered as a MyNetgear account at which point you will need to provide the credentials for that one as well to prove that it's yours.
You could try contacting support and have them guide you through it over teamviewer depending on your support entitlement.
