61gazza
Feb 16, 2016Aspirant
Cannot connect to RAIDar to set up device (network problem I think)? #26471247
Please help, I have spent an hour hanging on the phone to Netgear who were not helpful!
After turning on my Netgear only had blue flashing light, disc 1 was faulty as it was flashing so have pu...
BrianL2
Feb 16, 2016NETGEAR Employee Retired
Hi 61gazza,
Welcome to the community!
Your ReadyNAS is not obtaining an IP address from your router (network). Try to use another port or cable and see if that helps. With regard to accessing the device via its default IP address of 192.168.168.168, you need to set a static IP and subnet mask in your PCs NIC or LAN.
Eg. IP Address: 192.168.168.167
Subnet Mask: 255.255.255.0
Once applied, open up a web browser and access https://192.168.168.168/admin
Let me know if you have other question.
Kind regards,
BrianL
NETGEAR Community Team
