61gazza
Feb 16, 2016Aspirant
Cannot connect to RAIDar to set up device (network problem I think)? #26471247
Please help, I have spent an hour hanging on the phone to Netgear who were not helpful!
After turning on my Netgear only had blue flashing light, disc 1 was faulty as it was flashing so have pu...
61gazza
Hi Brian
thanks for quick reply
I did change the IP address to static before, so I changed it to what you suggested.
when I entered the http://192.168.168.168/admin I got the message
the connection has timed out
server 192.168.168.168 is taking too long to respond
not sure what to do now, I have been trying to sort this for three nights now, stressed out!
thanks
regards
gary
BrianL2
Feb 16, 2016NETGEAR Employee Retired
Hi 61gazza,
That seems odd. Can you check if you can access the data?
Kind regards,
BrianL
NETGEAR Community Team
- 61gazzaFeb 16, 2016Aspirant
This has been the problem, I cannot get into the RAIDAr, when I set the static IP address as you said, I clicked on setup and it went to browser but fails to display page, I really am at the end of my tether!
it looks like all is well lights on NAS box are lit ok, the set up page shows green lights but cannot access so I am stuck!
thanks for your help
Gary
