bshannon
Apr 20, 2017Aspirant
Can't backup TiVo Bolt using ReadyDLNA
Running 6.6.1 firmware, I'm trying to set up ReadDLNA to backup my TiVo Bolt. It's already set up to backup my TiVo Roamio and Series 3 so I know the Media Access Key is correct. However, when I c...
JennC
Apr 21, 2017NETGEAR Employee Retired
Hello bshannon,
Are you using a ReadyNAS OS6 or the legacy ones? I think you need Plex app for this.
bshannon
Apr 21, 2017Aspirant
OS 6.6.1, the current version.
I've never needed Plex for this before. As I said, it's working for my older TiVos.
Does Plex handle backups from the TiVo to the ReadyNAS?
I thought it was only for serving content from the ReadyNAS to the TiVo (and others).
- bshannonApr 25, 2017Aspirant
No ideas?
Is there a debugging or logging option I can enable for ReadyDLNA to help figure out what the problem is? I have ssh access to my ReadyNAS box.
Is the source code to readytivod available?
- JennCApr 26, 2017NETGEAR Employee Retired
Hello bshannon,
Honestly, I'm not really familiar how it looks like but I found that that the engineering is already aware that ReadyNAS' ReadyTiVO does not work with Bolt. This is something that they are still fixing.
- bshannonApr 26, 2017Aspirant
Ah, ok, I'm glad it's a known problem. Thanks for the response. I guess I just need to wait for the solution to be available...
