Zekeman1
Jun 15, 2015Aspirant
Can't connect to NV+ Admin
I have an NV+ on my network. Nothing complicated -- NV+, router, 2 pc's. With the exception of changing out the router, not much has changed. I can see the NV+ on the network, read and write to it,...
Jun 15, 2015Guru - Experienced User
You said you had no backup, Since your data is clearly at risk, you should start by copying anything you need off the NAS.
