Zekeman1
Jun 15, 2015Aspirant
Can't connect to NV+ Admin
I have an NV+ on my network. Nothing complicated -- NV+, router, 2 pc's. With the exception of changing out the router, not much has changed. I can see the NV+ on the network, read and write to it,...
Jun 15, 2015Guru - Experienced User
Likely the problem is a filling OS partition. If that is the case, you will lose CIFS access also (as it continues to fill).
Options would include
(a) paid (per incident) Netgear Support
(b) courtesy support from a Netgear employee who monitors the forum
(c) Do a factory reset, reconfigure the NAS and restore data from backup.
