Zekeman1
Jun 15, 2015Aspirant
Can't connect to NV+ Admin
I have an NV+ on my network. Nothing complicated -- NV+, router, 2 pc's. With the exception of changing out the router, not much has changed. I can see the NV+ on the network, read and write to it,...
Jun 16, 2015Guru - Experienced User
You can manually delete logs from the web ui periodically to help prevent this from happening again. If you are comfortable with ssh access, then enabling that also lets you monitor the OS partition usage.
Zekeman wrote: Looks like the issue has been solved by clearing out the logs. Thanks MDGM!
