cutyerheartout
Jun 15, 2013Aspirant
Can't Connect to ReadyNAS Duo from any device
Please help! I've pored through the forums and can't find an answer... I have a ReadyNAS Duo connected directly to an internal rounter (Netgear 3700). I use an iMac (10.8.4) direct ethernet conne...
Jun 16, 2013Guru - Experienced User
If RAIDar sees the device, then it will tell you the firmware and status (even if launching frontview doesn't work).
Do you see the NAs in the router attached device list?
How long have you had it? Did it ever work?
