cutyerheartout
Jun 15, 2013Aspirant
Can't Connect to ReadyNAS Duo from any device
Please help! I've pored through the forums and can't find an answer... I have a ReadyNAS Duo connected directly to an internal rounter (Netgear 3700). I use an iMac (10.8.4) direct ethernet conne...
Jun 16, 2013Guru - Experienced User
If you have a spare disk, maybe try powering down the NAS, removing both drives (keeping track of slot) and booting up with only the spare disk. That should do a factory default install, which would let you validate your hardware.
