cutyerheartout
Jun 15, 2013Aspirant
Can't Connect to ReadyNAS Duo from any device
Please help! I've pored through the forums and can't find an answer... I have a ReadyNAS Duo connected directly to an internal rounter (Netgear 3700). I use an iMac (10.8.4) direct ethernet conne...
vandermerwe
Jun 16, 2013Master
I think it is a disk problem.
You could confirm this by testing the removed disk using vendor tools while you are waiting.
By dumping I presume you mean you are doing a backup.
